Re: 89 Force 125 water exhast
Pops, I have never put one there, but you can put one on the right side of the motor as you look at it from the front. At the bottom of the long flat plate that usually has a wiring diagram sticker on it, there is a plug. At this point you could put a pee hole draining to the port side of the motor. You can also install the water pressure gauge that I referred to. A water pressure gauge is a lot easier to watch than a pee hole. Wilkin 250 , if you reading this, you install the brass oulet at this point and run the rubber hose that comes with the kit. nevjb
