Re: varying power levels
I think you are running on 2 cylinders most of the time, Loukel. It is when the third cylinder cuts in that you take off. If you are getting 130psi on all cylinders I don't see evidence of blow-by.<br /><br />It is pretty rare that I disagree with TMD. He is, after all, a real guru on outboards.<br /><br />First step is to determine if that is the case, then whether the dead cylinder is missing fuel or spark.<br /><br />Crank it up on the muffs, at idle. Short out each spark plug (CAREFUL
). Idle speed should drop in each case. If it doesn't drop on one, that cylinder is not making power. Test for spark.<br /><br />If you have good spark to a dead cylinder, spray some premix fuel into that carb. If the idle immediately goes up that carb is at fault, overhaul it.<br /><br />If none of the above tests reveal anything, inspect all of your ignition wiring for shorting to the block or to the cover.<br /><br />Let us know what you find, and good luck.
