I have a 1971 Chrysler 75 HP, 3 cylinder. The engine runs fine when I start it out of the water. When it is in gear on the water it will "miss" at high rpm and it will use 6 gal. of fuel in less than 15-20 minutes. Fuel will run out of the lower unit. The plugs are new. #3 cylinder plug does not get any carbon on it, It is wet with gas when I remove it. I have spark on all three cylinders. I noticed that it is putting alot of oil & fuel into the water. I removed the carbs and cleaned them. I did not put kits in them, however I didnt see any thing wrong w/ them. Could this be a fuel pump problem. Thanks
