Silvertip
- Sep 22, 2003
- 28,771
That buzzing was the warning horn telling you 1) the engine was overheating, 2) Low oil, or 3) no oil. Ignore #2 and #3 if this is not an oil injected engine. If its not oil injected, I hope you were using a 50:1 premix. If neither of the above is true, its no wonder the warning horn went off. If the warning horn was a steady buzz, that's the overheat warning. Since you don't know the history of the engine, you need to replace the water pump impeller, and while you are doing that, replace the thermostat. The scenario you described sounds like a stuck thermostat but a bad impeller will not provide sufficient water flow to properly cool the engine at higher speeds. Ignoring the problem can toast the engine. You are looking at about $40 bucks worth of parts -- hardly worth ruining an engine over. If you plan to work on it yourself, buy a service manual.
