Kajun37
- Feb 17, 2006
- 348
well..after going through 3 mechanics and still no working engine..i decided to try to fix it on my own using a manual and asking you guys for help
....well..2 mechanics said i had a bad power pack so i found a used powerpack and ignition coil set on ebay.....when it came in i used my cylmer manual and changed out one of the packs...dropped it in water.. it sounded much better..but it was still dieing out....i think i fixed the spark/power pack problem but i believe i have a fuel problem still.<br /><br />some pics for your viewing pleasure
packs and coils completely off!!then finished product
..i was proud of myself lol<br /><br /><br />
<br />
<br />
<br /><br />so..i came home and pulled the fuel pump to check and see if this one mechanic had rebuilt my fuel pump like he said he did and low and behold...he did NOT change one single thing on my pump..same gaskets and old diaphram...not only that he had the screen on BACKWARDS...here is a picture of the "NEW" diaphram he installed a couple weeks ago...stretched and not pliable...oh yea..he wants to charge me $40 + 2hrs of labor for rebuilding my fuel pump
..it will be a cold day in hell before he gets paid.<br />
<br />
<br /><br />so..now i need to rebuild my fuel pump...and while i'm at it i want to rebuild my carbs.....where is cheapest place to get these complete kits?..also i have never done this before lol<br /><br />i have bought and compression tester and a spark tester.....but i'm not sure how to use this stuff...someone told me i have to ground each spark plug to engine or i'm gonna fry more power packs.. so i'm scared to do it now......can i just pull one plug at a time and test it.. and leave the others in and plugged? or do i have to pull each plug and clip a ground wire to each coil wire to engine?<br /><br />also is there a way to do this with one person?i dont have anyone to come help me since i work late hours.<br /><br />next is compression check...can i check one cylinder at a time with me at center console... then when i'm done go back and check compression gauge? or will it not hold the test on gauge? or do i really need 2 people to do this?..can i check it cold?..because my engine wont run long enought to get warm
<br /><br />what is the best way to flush out a fuel tank without tearing apart my boats flooring and CC to get it out?<br /><br />and last question...how do i know which kit and what type of carbs i have..tolson or walbro?
