Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
A FRIEND GAVE ME A 1990 YAMAHA WAVERUNNER FOR A SPARE AT THE CABIN... IT WILL START FOR 5 SECONDS THEN QUIT AND WILL NOT HAVE ANY SPARK FOR HOURS OR DAYS. ANY HELP OUT THERE A NEW CDI BOX 400+
i doubt its the box if so it works or it dosent probably bad ignition wires change them first because the rule is cheepest and easiest things first when applying the wag system,, WILD AZZ GUESS, that rule dosent apply when you know whats wrong obviously. also look for loose ground wires another possability for sure
i have the same problem no spark have tested the coil its good and the switch its good i dont no about the pulse coils or the cdi but i had weak spark then none does ant one know about where all the grounds are
have you tested both sides of the start/stop switch? with a ski that age, the stop side could be causing your problem.
plug wires would also be suspect. you can either buy a new coil with attached wires, or send your current coil to John at www.jetskisolutions.com and he can replace the wires for you. His price is reasonable for that service.
