Working on a Sea Doo GSX Limited with a friend and it has a problem. It keeps blowing the 15 amp fuses,either the one in the back by the solenoid or the one mounted up on the CDI box. We have (I THINK) narrowed it down to a plug that goes into the motor by the oil pump,which I assume is the inner coils. The plug has 3 yellow wires,1 yellow/white wire and 1 black/yellow wire. It is intermittent,,sometimes it will start and run,and other times it will blow as soon as you put in the fuse. On a ampmeter it was pulling 17 amps before I pulled it off. When we unplug the plug from the motor,the problem goes away,but the motor will not start then. Any and all info much appreciated.
