motor heads and mopar fans
rwise
Some of you know that I am starting a rebuild on my old dodge (1984 royal SE) with a 318. I have not done anything like this in well 30 years! I am looking at a new cam (crane 693941 or more likely 693942 with lifters). I will do highway driving and towing (got to pull the boat) (and sometimes a (over)loaded trailer). Is there a better cam for what I am doing here, not going with radical pistons, want to run pump gas, will go with throttle body injection rather than the carb, already has MSD ignition that will interface with the computer for the fuel system (a GM adaption).
Kenneth Brown
Re: motor heads and mopar fans
My advice here goes for a carb and I don't know if your injection system will allow for the cam so..... I would stay with a lift less than .480 but above .460, Advertised duration around 260-270 degrees, and duration @ .05 lift no more than 214 degrees. This will still give you a good sounding cam that will not kill off the lowend torque. I put a cam like this in my old 66 GMC and it actually increased the mileage by about 2 mpg.
kenimpzoom
Sounds cool man.<br /><br />If ya wanna really wake her up, put a 2000 rpm stall converter in there.<br /><br />It will really wake up any engine combo and will help on the towing.<br /><br />Select whatever the "RV" cam is. Dont get radical or your fuel injection will be a pain.<br /><br />Ken
Ron G
Rwise can you show some pics??i have my dads old 85 and my grandfathers 87 just a siting,i hope one day to do something with them maybe i can make 1 good one out of the 2.
rwise
I don't want to get radical with this one, know when I start the 65 barracuda sport formula, well thats another story.<br /><br />There was also another cam 694105 with not as much lift, that could work well also and had lower end torque down to 800 rpm. both are smooth idle. specs on both below, the first one may be more than I want,,,,,,,,,<br /><br /><-------------------------------------------><br /><br />Part Number: 693941 Grind Number: H-272-2 (REPLACES HMV-272-2) <br />Engine Identification: <br />Start Yr. End Yr. Make Cyl Description <br />1964 Up PLYMOUTH-DODGE-CHRYSLER 8 GOOD IDLE, DAILY USAGE AND OFF ROAD, TOWING, PERFORMANCE AND FUEL EFFICIENCY, 2600-3000 CRUISE RPM, 8.75 TO 10.5 COMPRESSION RATIO ADVISED. BASIC RPM 2000-5000 <br />Engine Size Configuration <br />273-360 C.I. V <br /> <br />Valve Setting: Intake .000 Exhaust .000 HOT <br /> <br />Lift: Intake @Cam 3027 @Valve 454 All Lifts are based <br />on zero lash and theoretical rocker arm ratios. <br /> Exhaust @ Cam 3200 @Valve 480 <br />Rocker Arm Ratio 1.5 <br /> <br />Cam Timing: TAPPET @.004 <br />Lift: Opens Closes ADV Duration <br /> Intake 25 BTDC 67 ABDC 272 ° <br /> Exhaust 75 BBDC 29 ATDC 284 ° <br /> <br />Spring Requirements: Triple Dual Outer Inner <br />Part Number 99835 <br />Loads Closed 113 LBS @ 1.600 or 1 19/32 <br /> Open 302 LBS @ 1.140 <br /> Recommended RPM range with matching components <br />Minimum RPM 1800 <br />Maximum RPM 5400 <br />Valve Float 6000 <br /> <br />Cam Timing: TAPPET @.050 <br />Lift: Opens Closes Max Lift Duration <br /> Intake 1 BTDC 35 ABDC 107 216 ° <br /> Exhaust 51 BBDC (3) BTDC 117 228 ° <br /> <br /><------------------------------------------><br /><br />Part Number: 694105 Grind Number: POWERMAX 2010 (FORMERLY COM <br />Engine Identification: <br />Start Yr. End Yr. Make Cyl Description <br />1964 Up PLYMOUTH-DODGE-CHRYSLER 8 "LA" <br />Engine Size Configuration <br />273 C.I. V <br /> <br />Valve Setting: Intake .000 Exhaust .000 HOT <br /> <br />Lift: Intake @Cam 271 @Valve 407 All Lifts are based <br />on zero lash and theoretical rocker arm ratios. <br /> Exhaust @ Cam 256 @Valve 384 <br />Rocker Arm Ratio 1.50 <br /> <br />Cam Timing: TAPPET @.004 <br />Lift: Opens Closes ADV Duration <br /> Intake 20.0 BTDC 50.0 ABDC 250 ° <br /> Exhaust 49.0 BBDC 11.0 ATDC 240 ° <br /> <br />Spring Requirements: Triple Dual Outer Inner <br />Part Number -- <br />Loads Closed -- LBS @ -- or -- <br /> Open -- LBS @ -- <br /> Recommended RPM range with matching components <br />Minimum RPM 800 <br />Maximum RPM 4200 <br />Valve Float 4800 <br /> <br />Cam Timing: TAPPET @.050 <br />Lift: Opens Closes Max Lift Duration <br /> Intake (6.0) ATDC 20.0 ABDC 103 194 ° <br /> Exhaust 23.0 BBDC (19.0) BTDC 111 184 ° <br /> <br />Remarks: <br />1992 AND LATER MODELS WITH PEDESTAL TYPE ROCKER ARMS USE A 1.60 ROCKER ARM RATIO.
rwise
Originally posted by Ron G:<br /> Rwise can you show some pics??i have my dads old 85 and my grandfathers 87 just a siting,i hope one day to do something with them maybe i can make 1 good one out of the 2.
I am at work now, but I'll see what I can do this weekend, how deep do you want?<br /><br />BTW they are great trucks, lots of them still on the road, and my son has one almost like mine, his has the 360,,,,,
rwise
Ron one more thing, if they run, start them up and run oil down the carb until they smoke really good and shut them off. It will help with waking them back up later,,,,,,,,,
Ron G
Whatever you can show,i'd like to see some body pics,thanks.my neighbor down the road has 69 charger and is building a challenger right now.
rwise
oh the thing I dont like about the 694105 cam is the 4800 rpm valve float, my distributer doesn't make full advance curve until 6000 rpm :eek:
rwise
I'll get those up Ron! Looks like I'll need a place to post pic's ;)
Kenneth Brown
Originally posted by rwise:<br /> oh the thing I dont like about the 694105 cam is the 4800 rpm valve float, my distributer doesn't make full advance curve until 6000 rpm :eek:
Surely not. Most of the time your advance will be all in by about 2300. I would check on that figure again.
rwise
It is a MSD with no vacume advance, I may go back to the stock part for the truck though!
rwise
Ron G<br />here you go,,,,,,,,,,<br /><br /><br />
<br />
<br />
<br />
<br />
Kenneth Brown
Can I have the yeller pinto in the background? It would be awesome with a 347 stroker in it.<br /><br />I'd say the change out the springs in the dist if it really is set at 6000. Being that high the spring cams would probably be off also. I've never heard of an advance curve waiting that long to come fully in.
rwise
The girl that own the there yeller pinto will not turn loose of it, she loves that thing. She has another just for parts! It is her daily driver, though it needs trany work now,,,,,,<br /><br />I keep that distributer behind the seat! Only used it when I was running with Hemi's, when they run out of computer I'm just startin to wind up! I don't think that it will ever go back into the truck, and the Barracuda I want the vacuum advance on it. I think it pushes the engine to hard!
Ron G
Nice,going to make a good truck,those pick-ups look so good fixed up.
