Re: PC gurus -net working ? ---- UPDATED
Did you program the router and change the default SSID?? <br />Did you change the default router password?<br />Did you turn on encryption, either WEP or WPA?<br /><br />It's pretty easy to connect to your router via Cat5 cable, since Windows DHCP is enabled by default. <br /><br />When you're first getting the router setup, it best to NOT have encryption turned on. Later , when your're connected to the router wirelessly, you can turn on Encryption, but for now leave it off.<br /><br />Open your browser<br />On the address (URL) line,type in 192.168.0.1.This is the IP address for your router. Enter 'admin' for the user name,leave the password box empty. <br />Find the menu section to change the default SSID. The SSID is the name of your wireless router. Change the default name (default) to a unique name, TieOneOn, comes to mind. Click on the save tab. Change the wireless channel to either 1 or 11, hit save. Change the default router password, it's blank by default. Don't use a simple password here, add a few non dictionary characters mixed in, and use upper and lower case too. Example: tie$*thi$OnforKi#cks...you get the idea. Now write this password down,keep it safe. Do NOT click the option to hide the SSID. Save your settings.<br /><br />Run your Gateway machine. Unplug your Cat5 cable.Insert the USB NIC. Run the USB NIC client manager program. Do a scan for available networks. It should show "TieOneOn", that's your router. Click to connect. <br /><br />Confirm that you can surf the Web. If all goes well, you should be good to go. Lastly, go back into the router and turn on WEP or WPA. This keeps folks 'outta your router and freeloading on your dime. btw, use WPA if at all possible, WEP has been cracked. Don't rely on MAC address filtering or hiding your SSID to keep others out. I can find your MAC address and router SSID in 10 seconds. Turn on WPA-TKIP, and don't use any dictionary words...ever...mix up the code as mentioned before. <br /><br />There.....that should keep you busy for awhile...(grin)
