Re: Cavitation plate...How high?? or how low??
I have an 18' Nitro NX882 bass boat with a Merc 150HP engine on it. When I bought the boat, it pulled really hard to the right, and when I would turn to the right more than just a slight curve, it felt like the engine wasn't getting any grip, and the boat would slip sideways really bad. Turning left didn't do this.<br /><br />First thing I did, was buy a trimtab for it. It still pulled to the right, untill I trimmed the engine way up (At which point the boat became QUITE unstable. I would hit a small wave, and the boat would start pourposing, and just keep going higher & higher & higher untill I trimmed down and pulled back on the throttle). It did help some, however.<br /><br />The next thing I did, is lower the engine 2 notches. Before I would hit 60mph at about 4700RPM, but now, I hit 60MPH at about 5200RPM and it just won't go any faster (I have a 23" prop. I've got a 21" in my garage I need to try out). Lowering the engine did give me MUCH more stabillity, however. Just at the cost of some speed (Which is fine, I normally cruise under 40mph). When the engine is trimmed all the way down, it still pulls to the right, but not nearly as bad as it used to...<br /><br />Hope this helps!<br />Mike Carlson
