Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Thanks Dave and dhadley. Boat is performing fine and seems to reach approppriate RPMs and speed, however I was told that I could expect improved performance with a stainless prop. I'll look for the prop forum. Thanks for the FYI.
The improved performance comes largely due to the fact that a ss prop will (most times) run at a higher X dimension than an aluminum one. Raising the motor to find the optimum height (X dimension)for any given prop on a specific rig results in less drag and therefore better efficiency. From holeshot to wot.<br /><br />It's all in the set up.....
