All,<br /><br />I recently repowered an 18CC Angler with a 115 Suzuki 2 Stroke outboard. Engine runs fine, but I think I'm having a problem with prop. The first prop I tried was a 3 x 13.25 x 18 stainless. It seemed fine, but could not get to the recommended RPM range, which is 4800-5500. Second prop was a 3 x 13.25 x 17 aluminum which got me to 5200 rpm, but cavitated when I tried to trim up to the correct bow angle at max RPM. <br /><br />One thing I noticed was that the cavitation plate on the boat is not at the keel level its about 4 off the bottom. The folks who did the repower tell me that is how it should be. My question is: when at Max RPM, is the maximum trim angle less than it would be when I am running below max RPM? The boat seems to plow when I am at 5200 with the 17 pitched prop. Related question: Is there a prop that will get me to max RPM AND higher bow trim angle without cavitating? <br /><br />Sorry if this sounds dumb; Im not that experienced with Prop problems, and trying to figure it all out. <br /><br />Joe
