Re: Newbie Mercruiser TRS Drive Problem
I can get the lower unit into forward, but i'm still having a problem with the collar looking deal the comes from the upper drive unit to spline on the lower unit shift shaft.  It stays in the down position, and can spline in what seams like 2 positions.  Is that normal? or should i be taking off the upper drive unit, and reassmble from scratch?
  But when I do get the thing together, I only have forward and nuetral then the shifter starts to bind, and before forcing it, I then remove the lower unit, and everything is free again.  Is that just a cable adjustment issue?
