Re: Starter not spinning fast enough!!!!
Voltage drop test for your cables & connections:
Use a digital volt meter that measures 1/10 of a volt.
Positive Battery Cable
1. Connect the red lead on the meter to the positive battery post.
2. Connect the black lead on the meter to the starter solenoid terminal where the positive battery cable is connected.
3. Have someone engage the starter. A reading above 0.6V indicates a bad cable or bad connection.
(a) If the meter reads above 0.6V, move the black lead on the meter to the positive cable terminal at the solenoid and retest. If the reading drops to below 0.6V, the connection is bad.
(b) If the meter still reads above 0.6V, move the black lead on the meter to the positive cable terminal
at the battery and retest. If the reading drops to below 0.6V, the cable is bad or undersized.
(c) If the reading is still above 0.6V, the connection at the battery is bad.
Negative Battery Cable
1. Connect the black lead on the meter to the negative battery post.
2. Connect the red lead on the meter to the engine block where the negative battery cable is connected.
3. Have someone engage the starter. A reading above 0.6V indicates a bad cable or bad connection. A reading above 0.6V is an indicator of a bad cable or bad connection.
(a) If the meter reads above 0.6V, move the red lead on the meter to the negative battery cable terminal at the
engine block and retest. If the reading drops to below 0.6V, the cable connection is bad.
(b) If the meter still reads above 0.6V, move the red lead on the meter to the negative battery cable terminal
