when installing new rings in a marine engine are moly better then plain steel for use. thanks
Q qaztwo Petty Officer 1st Class Joined Jun 26, 2004 Messages 384 Jul 4, 2006 #1 when installing new rings in a marine engine are moly better then plain steel for use. thanks
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,414 Jul 4, 2006 #2 Re: piston rings Piston Rings are Cast Iron,.......... I'd go with the Moly coated 1s.......
Q qaztwo Petty Officer 1st Class Joined Jun 26, 2004 Messages 384 Jul 4, 2006 #3 Re: piston rings I thaught the same thing about the plain rings to. Moly's are supposed to last longer, but in marine applications does it matter.
C calwldlif Petty Officer 1st Class Joined Aug 16, 2002 Messages 348 Jul 4, 2006 #4 Re: piston rings There are different honing specs for Moly rings. Make sure you tell you machinist the type rings you are using so he/she will put the right pattern
