Need help flushing 1977 Johnson 6HP
jschock
I cannot seem to find where to attach the earmuff to flush the engine and/or test it out of the water. There is a small area on the lower right side that has small lovers but it does not seem to allow water in and out of the engine.
Can someone tell me excatly where I hook the earmuff.
Thanks
Jeffrey
Rattle-
Re: Need help flushing 1977 Johnson 6HP
Jeffery,
There should be screened holes on either side of the lower unit. Attach there. However I may be wrong, as I have ever only owned one outboard.
Kerry
tashasdaddy
it's easier with the small one to run in a barrel or large garbage can.
iwombat
My '76 has a vent panel on both sids just above the cavitation wings/planes/whatever they're called. That's where the muffs go. Your '77 should have the same thing.
jschock
jschock
jschock said:
No there is only two small slits on the right side.
jschock
Your are probably right but I have the earmuffs and don't have a barrel or trash can the correct size. May have to go that way.
Thanks for reply
Jeff
iwombat
Well, gee. Closer inspection on the '76 reveals one side only too.
Who knew?
Anyway, you found 'em.
tashasdaddy
gee did you feel dumb, i do all the time.
iwombat
More dorky than dumb, but thanks for checking in.
Rancherlee
5 gallon pail works GREAT for these 6hp, I run my 78' 6hp rude' in one. about 3-4$ at a hardware/paint store.
Scaaty
Any Home Depot, WalMart, or ? has quite a selection of buckets last I looked
