Re: Old Info
As this is copied from Wordperfect 10, it didn't format perfectly, I apologize for that...the prop, manufacture, rpm and speed are listed after each prop and if you read carefully, you can extract those numbers.
I hope this is of some use to all who read it. I learned many things about blade design during this testing and some designs are just not suited for some applications, but I did get a very good feel of how each design performs and where it is best suited.
If you have any questions, please, ask away.
Remember, these are all SS props.
PROPELLER TEST RESULTS
FOR 3-BLADE STAINLESS, THRU-HUB EXHAUST DESIGNS.
BY KENNY SANDERSON
2 PROPELLER DESIGNS WERE THE FOCUS OF THIS TEST
#1. WAS TARGETED FOR HIGH-END PERFORMANCE, THRU-HUB DESIGNS FOR HIGH-PERFORMANCE, OUTBOARD TYPE HULLS.
#2. WAS TARGETED AT THE HEAVIER, STERNDRIVE AND CENTER CONSOLE-TYPE BOATS WHERE LARGE BLADE AREA IS REQUIRED FOR BEST PERFORMANCE.
THE BOAT COMBINATION USED FOR THE TESTING IS AN 18FT., ALUMINUM DEEP-V WITH A 6 INCH JACKPLATE WITH TRANSOM MODIFIED TO HANDLE A 2.5L, 200HP EVINRUDE.
MOBSTER TABS BY NAUTICUS INC, WERE INSTALLED TO ALLOWED THE SPEEDS ATTAINED
DURING THE OPERATION OF THIS BOAT AND CREATED A SAFE PLATFORM WITH EXCELLENT HANDLING QUALITIES.
SOME PROPS ARE LISTED TWICE, NOT ALL PROPS WERE TESTED ON THE SAME DAY, BUT EACH PITCH GROUP WAS RUN ON A SPECIFIC DAY, SO DATA FROM EACH PITCH WILL BE UNIFORM TO CONDITIONS.
TEST CONDITIONS ARE AS FOLLOWS FOR THE DEEP-V ALUMINUM PLATFORM.
FOR LOAD SIMULATION, SAND BAGS WERE USED FOR WEIGHT, POSITIONED WHERE PASSENGERS WOULD NORMALLY BE.
FOR THE HIGH-PERFORMANCE PROPS, 19P AND UP, 200LBS OF SAND BAGS WERE PUT WERE THE PEDESTAL FOR THE LEFT SEAT WOULD BE.
FOR 17P AND SMALLER, 600LBS OF SAND BAGS WERE ADDED TO SIMULATE A HEAVIER TYPE BOAT.
FOR THE LARGE BLADE AREA PROPS, 200LBS OF BAGS WERE PLACED IN THE LEFT SEAT POSITION AND 400LBS IN THE REAR WITH AN ADDITIONAL 200LBS FORWARD OF THE CONSOLES.
ALL REQUIRED GEAR PLUS 175LBS OF TACKLE, A 24 VOLT 62 INCH MINNKOTA TROLLING MOTOR WITH 2 GROUP 31 BATTERIES WERE ALSO LEFT MOUNTED TO SIMULATE ACTUAL, REAL-WORLD CONDITIONS.
PLEASE KEEP IN MIND, MY RESULTS ARE UN-BIASED, I WAS NOT PAYED OR REIMBURSED IN ANY MANNER TO TEST THESE PROPELLERS, THIS TASK IS ALL MINE AND TOTALLY INDEPENDENT OF ANY AND ALL MANUFACTURERS.
THE HIGH-PERFORMANCE PROPS WILL LIST TOP RPM AND SPEED VIA GPS. THIS LIST WILL ALSO INCLUDE VENT HOLE SIZE IF SO DESIGNED BY FACTORY.
HOLE-SHOT CHARACTERISTICS WILL BE LISTED AS WELL.
IN SOME CATEGORIES, THERE WILL BE PROPS OF 1" TO 2" DIFFERENT PITCH AS REFERENCE PROPS FOR COMPARISON.
ON THE FOLLOWING PAGES, THE BOAT, PROP MANUFACTURER AND SIZE WILL BE LISTED, WITH SPEED VALUES AND RPM. HOLE-SHOT AND/OR VENTING HOLES WILL BE NOTED AS WELL. ALL PROPS WERE RUN TO MAX EFFICIENCY AND ONLY TOP FIGURES WILL BE LISTED.
ALUMINUM DEEP-V, 200 EVINRUDE, PERFORMANCE PROPS
MANUFACTURE RPM MPH NOTES
OMC 15X17 6350 48.1 GOOD HOLE-SHOT
TURBO1 14.25X17 6300 50.9
STILETTO 14.25X17 6300 50.2
VIPER 14.875X17 6200 48.8
BALLISTIC 14.75X17 6150 46.6 VENTS EASILY WITH TRIM
RAPTURE 14.25X17 6250 47.4 VENTS ON HOLE-SHOT
RAPTURE 14.25X19
6100
49.9
MWC 14.5X19 6100 52.0 GOOD HOLE-SHOT
BALLISTIC 14.5X19 6000 50.6 HOLE-SHOT SLOWER
TURBO1 14.25X19 6050 53.1
OMC SST 14.5X19 6100 52.1
RAKER 14.5X20 5800 54.7 3/8" VENTS EXCELLENT HOLE-SHOT
MWC 14.25X21 5750 53.9 FAIR HOLE-SHOT
BALLISTIC 14.375X21 5700 53.2 POOR HOLE-SHOT
VENTED 3/8"
OMC SST 14.25X21 5700 54.2
VIPER 14.875X21 5650 54.4 GOOD HOLE-SHOT 5/16" VENTS
TURBO 14.25X21 5700 55.4
MW EDGE II 14.25X22 5700 54.0
RAKER 14.5X22 5600 55.1
TEMPEST +14-5/8X23 5400 55.7 GOOD LIFT
RAKER 14.5X24 5250 56.1 HIGH CYL HD TEMP
SCORPION 15-1/8X24 5250 56.3
BALLISTIC 14.5X24 5200 54.7 VENTS EASY AT HEIGHT
MWC 14.25X24 5200 54.9
TURBO 1 14.25X25 5050 55.4 HIGH CYL HEAD TEMP
RAPTURE 14.25X25 5100 55.0
SCORPION 15-1/8X26 4900 56.1 STILL FAIR HOLE-SHOT
TEMPEST 14-5/8X26 4950 57.3 GOOD HOLE-SHOT WITH PLUGS REMOVED
BALLISTIC 14.5X26 4900 54.9
RPM BELOW NEAR 5200 SHOWED HIGHER THAN NORMAL CYLINDER HEAD TEMPS AND HIGH FUEL CONSUMPTION
HEAVY LOAD PROPS
MWC 013052 15X15 6550 42.1 PUSHES 800LBS OF SAND BAGS LIKE THEY ARE FILLED WITH AIR
LEXOR 15.75X15 6500 41.9
MIRAGE PLUS 15.75X15 6500 41.7
OMC 431930 15X17 6300 44.6 SLOWER HOLE-SHOT
LEXOR 15.5X17 6250 45.2
VENGEANCE 14.5X17 6300 44.8 LITTLE SLOW OUT OF HOLE
BALLISTIC 14.75X17 6100 44.1 NOT A GOOD LOAD PROP
MWC 14.5X19 5850 47.6 SLOW HOLE-SHOT-NO VENTS
VENGEANCE 14X19 5850 46.9
MIRAGE+ 14.75X21 5500 48.6 HOLE-SHOT BETTER THAN EXPECTED
LEXOR 15X21 5500 49.1 HOLE-SHOT AS ABOVE WITH GOOD MID-RANGE
TURBO 1 14.25X21 5550 48.0 VENTED BUT PRETTY SLOW HOLE-SHOT WITH MAX LOAD
VENGEANCE 13.75X21 5600 48.2 NO VENTS AND SLOW HOLE-SHOT, BUT GOOD MID-RANGE
