1991 25HP Merc "kills" at half throttle
inthwtr
Cant figure this one out. Engine runs fine at low speed but as soon at I (its a tiller) twist it to more than half throttle, it dies. Almost as if the ignotion is "killing" it.
Again, the engine runs fine at just below half throttle.Suggestions please!:%
tashasdaddy
Re: 1991 25HP Merc
Re: 1991 25HP Merc
could you be hitting the kill button by accident, does it have a lanyard that could have a loose fit. have you check the wiring,
Laddies
Banned
Re: 1991 25HP Merc
Re: 1991 25HP Merc
Unplug the kill wire at the switchbox (blk/Yellow) be sure it is the one to the kill switch as there are 2, mercurys messup I guess if it don't run then it's probably thr high speed winding on the stator. It can be OHM tested
tashasdaddy
Re: 1991 25HP Merc
Re: 1991 25HP Merc
go t outboardparts.com mercury trouble shooting, there is a step by step procedure. i point you there because our engine faq section is and has been down.
inthwtr
Re: 1991 25HP Merc
Re: 1991 25HP Merc
I have checked the wireing and even tried disconnecting the kill switch. It still does it. Can you explain what a high speed stator does?
inthwtr
Re: 1991 25HP Merc
Re: 1991 25HP Merc
Outboardparts.com seems to be down. I cant get any of the pges tp open
Laddies
Banned
Re: 1991 25HP Merc
Re: 1991 25HP Merc
Under the flywheel there are 2 winding that produce the AC electricity to operate the ign system one is for starting and low speed operation as the RPM increases the low speed would produce to many volts for the system so it has a high speed winding that takes over and it also acts as a resistor (for lack of a better term) for the lowspeed for power at about 2500 RPM
inthwtr
Re: 1991 25HP Merc
Re: 1991 25HP Merc
Now this is starting to make sense!!! Where do I get this winding to replace!?!?!? And Thank you!
tashasdaddy
Re: 1991 25HP Merc
Re: 1991 25HP Merc
maxrules.com, mercpartsexpress.com or a dealer.
