Re: 84 evinrude 150 to a 175
In those years, the blocks are the same, with the exception of the carbs. The 175 (or 200) carbs have a larger throat and larger jets. (You will have to play with the jets on the 200 carbs to get them to run on this low-port engine.) It is a simple swap. You could also add the crankcase filler blocks-322722. They are cheap and will also help. While NLA, there are many around. You may find better overall operating characteristics with composite reeds. A set of heads will help wake up the engine. 235 heads are another bolt on which will greatly help performance. The more you do, the more you need to be able to read plugs to make sure you don't fry the powerhead.
