imported_Jerry
- Jul 21, 2006
- 11
Had boat out this morning and continuous alarm went off. Motor died, but re-started and I could creep back to the boat ramp in idle speed only. At ramp, motor turned over real easy when out of the water. Soon as put in the water, would cut off. Water continued to stream out the back all along, so there was no stoppage of water. Any suggestions?
Just got back from the shop and they say the impeller went out, which caused the #5 cylinder to burn out. Given an estimate of $1500 to $2000 to repair (parts and labor) since they will have to take the whole engine apart. Does this sound right?
Also, did running it with the alarm sounding for a short distance cause the cylinder to burn out?
Thanks to all that have and are helping.
