Re: Ethanol vs 87+ octane Fuel
Per my 2005 150 mercury manual, under the title of Alcohol in gasoline it states:
"we do not recommend the use of gasoline which contains alcohol (a.k.a. ethanol) because of the possible adverse effect the alcohol may have on the fuel system. In general, if only gasoline containing alcohol is available, it must not contain more than 10% ethanol or 5% methanol, and the addition of a water separating fuel filter is recommended."
It then goes on to state that "these refomulated fuels are acceptable for use in the mercury engine."
