Re: 1977 70hp evinrude running sluggish
Hi everyone & thanks to all for your help so far...
The boat is running better after carb and fuel pump rebuild, new fuel lines, link & sync, ect. No longer need to choke to get up to speed BUT it does hesitate when I hit the throttle before kicking in. I can minimize this by accelerating slower but if I "jump on it" from idle speed, she hesitates before taking off. No "cough" from the engine just a lag of about 1 sec.
Also while running in my driveway (w/ muffs and in a barrel for exhaust pressure) she occassionly "misfires,coughs and/or spits" which drags rpm's down before recovering. Doesn't happen so much if I increase idle speed. Swapped coils around as I was getting an erradic tach reading from #1 cyl. but it didn't make a difference (Tach would occassionly drop before recovering). This went away after moving coils so maybe just dirty connections.
Anyway, I'm no mechanic but I'm enjoying the $ savings and getting intimate w/ my boat. Please help if you have advise on above.
I'll be in the water tomorrow to adjust max rpm, check timing and idle speed.
Thanks
chris
