Re: no gas to carb
Welcome to iboats!
Disconnect the fuel line from the carb. Put this line into a tin can. Squeeze the primer bulb, does fuel squirt into the can? If yes, then pull the rope start, does fuel squirt into the can? If yes, replace fuel line to carb.
You have determined that the fuel pump is working and the fuel is being delivered to the fuel pump and carb.
If the motor burps, it's getting some amount of fuel, but perhaps not enough. Try spraying a bit of fuel mix (gas/oil mix) directly into the carb throat with a spray bottle. Pull rope start. Does motor run for a few seconds? If yes, you have a fuel blockage in the carb. Remove carb. Clean with spray carb cleaner followed with compressed air in all openings and passages. Install carb kit. Remount carb.
BTW, replacing the 9.9 carb with a 15hp model is going to be a problem. The 15hp carb throat is larger than the original 9.9 carb throat and will tend to flood the motor.
