I have a 1987 yamaha model JD50ESH.
For the last 2 months I have been trying to fix a loss of power problem.(800rpm). Here is what I have done/tried.
confirmed fuel supply, including pumping the primer bulb while running at speed, and squirting fuel directly into carb while running. No change while pumping. Bogged down when fuel was squirted into each carb.
I replaced the head gasket. I then took it out for a trial run and thought I had fixed the problem. The motor ran great thru out all ranges untill the motor reached max. temp. or about 10 minutes.
I have checked the plugs many times and they appear equally fine.
appears to have good water flow for cooling.
Although the power loss is the same while idling and full power, during full power runs sometimes (usually while running with little added weight in the boat) there is a split second gain of power every few seconds.
I was going to re-build the carbs but after replacing the head gasket and then having it run fine for the first time in months tells me that the carbs may not be the problem.
Whould a warped head cause the symptoms described? I checked for water intrusion after replacing head gasket and found no sign of water.
cylinder compression while cold is 120-115.
I bought the motor new and have not changed any original settings.
Any suggestions will be apreciated, thanks
