I have a 19.5 ft open bow I/O. I'd like to install a Ski Pylon in the boat, but i'd like it to be as unobtrusive as possible. Boats that come with this equipment standard, often have the base of the pylon located at the front of the engine cover, with an extension that you add to the top of that when in use. This is exactly what I'm looking to install in my boat. However, everything I've seen has at least two supports that extend out toward the back of the boat. Has anyone had any luck installing one of these below the engine cover with the supports remaining below the engine cover? My cover extends the entire width of the beam of the rear of the boat, so with a standard add-on pole installed, I wouldn't be able to open the cover to access my engine if I needed to in a hurry.
Any help would be greatly appreciated... more so if it included pictures.
