Question for Joe Reeves.
Theoutdoorsman
Can you post a link to your "link and sync" directions. I've been trying to locate it but am having some trouble finding it using the search feature. Thanks a bunch..............ALAN
OBJ
Re: Question for Joe Reeves.
Hi Alan.....Joe has a tremendous procedure for adjusting low/high speed needles (which you can find in the FAQ's) but I don't recall any for sync/link. Engines being as differenct as they are and the procedure for the larger engines is quite long.....be hard to post a "do all" sycn/link procedure.
What have ya' got? Lotta' guys here to help.
Theoutdoorsman
Hi again OBJ. And thanks for the reply. I seem to recall a lync and sync procedure, posted on here one day, that could supposedly get a person very close to where they would need their timing set before the initial testing (starting) of a newly rebuilt powerhead. I'm currently waiting for my parts to be returned to me via Mar-Fab so that I can begin rebuilding my '79 Evinrude 140 HP. I just wanted to study the idea beforehand. I have the OEM service manual and parts manual on my motor, and have glanced at this a little bit. I just wanted to see what differences there were between the two procedures, but I can't seem to find the posting on here again. Come to think of it, you very well may be referring to the posting I read. I just can't recall. Anyhow........just trying to study all I can for this rebuild. Thanks again..........ALAN
tashasdaddy
there is a linc and sinc procedure for the in line Mercs in the engine faq, but the johnny/rude procedure, is totally different. you really need the oem manual for your engine to do that procedure..
Mark42
Here is Joe's procedure for Johnson timing adjustment:
"Try this procedure from Joe Reeves Mark. It works.
(Timing At Cranking Speed 4°)
The full spark advance can be adjusted without have the engine running at near full throttle as follows.
To set the timing on that engine, have the s/plugs out, and have the throttle at full, set that timer base under the flywheel tight against the rubber stop on the end of the full spark timer advance stop screw (wire it against that stop if necessary).
Rig a spark tester and have the spark gap set to 7/16". Hook up the timing light to the #1 plug wire. Crank the engine over and set the spark advance to 4° less than what the engine calls for.
I don't know the full spark advance setting your engine calls for, but to pick a figure, say your engine calls for 28°, set the timing at 24°. The reasoning for the 4° difference is that when the engine is actually running, due to the nature of the solid state ignition componets, the engine gains the extra 4°.
If you set the engine to its true setting at cranking speed, when running it will advance beyond its limit by 4° which will set up pre-ignition causing guaranteed piston damage! You don't want that to take place.
No need to be concerned about the idle timing as that will take care of itself. The main concern is the full advance setting.
Be sure to use your own engines spark advance settings, not the one I picked out of the air here in my notes. "
Theoutdoorsman
Thanks a bunch Mark42...Much appreciated!!............d:)
