voith driver
- Aug 9, 2006
- 2
hi all,
just found this site, as i am having trouble with a couple of outboards decided to see if someone can help me, and this site looked very good.
at the moment i am working on a johnson 20 RL 73A, because the lower end got trashed, stripped its lower pinion, and sheared its driveshaft, not only that but the gear case was without oil, so i am in the process of rebuilding, and hsve come to a screaming halt.
i am trying to change the oil seal that is located in the seaward end of the gearcase head assembly, in the parts book it shows it as a single unit, however the workshop manual shows it with a oil seal and o-ring, and in the text it simply states that
remove the seal from the gearcase head and discard the o-ring
hmmmmm, yes, well, reads nice and simple, but heres the rub, how the devil do you get to it, on inspection, it looks as if the only way to get to it, is to take the bronze bearing/bush outon the inboard end but it all seems as though its a sealed unit,
basically HELP
thanks
voith
basically HELP
thanks
voith
