Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
my front green/red navigation light isnt working... i took it off and put a voltmeter on the 2 wires... i'm getting a reading of .59 volts....what should i be getting there? the fuse is good.... any troubleshooting help would be appreciated
You should be getting 12 volts. If the fuse is good and the fuse holder is corrosion free check the ground wire. Also make sure you have 12 volts going into the fuse.
