OK this is my first post to these forums so be gentle!!!
I have a 1980(?) 15 HP Evinrude (model E15RCRM) that is having starting issues. When I first started looking into it I found that I was getting spark and getting gas to the carb but it would still not turn over. No fire at all. I did some digging and found that the shear key on the flywheel shaft was broken. I replaced the key and instantly it fired up. Now the issue is it will not stay running. It fires up almost every pull runs for about 5-10 seconds and dies. I tried all of the following to no avail. The problems still exists.
- New plugs
- Fresh gas and a new fuel line (I first thought the fuel line was not seating properly and air was getting into the line. Not)
- Pulled carb and cleaned it along with the jets
- Checked the float and float needle
- Adjusted idle screw
- Adjusted the Air/fuel mixture screw
I have run out of ideas so now I turn to you, fellow enthusiasts, for other ideas. One thing I'm not sure about is the air/fuel mixture screw and how it should initially be set. I turned it all the way in (lean) and backed it off about a half a turn. Is this correct? I tried turning it out a half turn between each start until all the way out (rich). No matter the position I got the same result. Is it possible the fuel pump is bad?? Is there a check for this?
Any help you guys (or gals) could provide would be greatly appreciated.
Many thanks in advance.
Eric B
Racine, WI
- New plugs
Eric B
Racine, WI
