From a combination of fiddling without knowledge and forgetfulness we have ended up with a burnt piston and a badly scored bore, in one of the two cylinders, the really cutting thing is that the rest of the engine is perfect, the top cylinder has 150PSI.
Qu 1. Is it possible to rebore the engine and to what size do you re bore it?
Qu 2. can this be done by a motor vehicle engine reconditioner or does it have to be done by a marine specialist?
Qu 3. Where can over sized pistons and rings be found
Qu 4. Is it worth it?
I have a seloc manual for the engine but it doesn't give you any guidance on this
Thanks for you advice
James
James
