Hi All, the motor was running well and would start right up until I put it in gear, it would die. I decided to pull the carbs off and clean them out. I soaked them in cleaner and used a compressor, not real difficult. I put the carbs back on and now the motor will not start at all. I pulled the plugs and noticed they were soaked so abviously it is flooding and getting too much gas. Plugs are brand new too and it is getting spark. Is there a setting that may be off or possibly the float needs to be adjusted on the carbs?
