4 hp low compression
Following up on advice received earlier from this forum, and while awaiting my carb kit, I did a compression check on this motor which I recently purchased at a yard sale (Evinrude s/n 4206s)
With both plugs out, and throttle wide open, I checked the top cylinder first, with a reading of around 60 psi. Then I checked the lower cylinder and got a reading of 80 psi. Did this twice....same reading
Engine was cold of course as I can't get it going
Can anyone advise on what this means exactly..is this motor worse off than i first thought. Did I do the compression check right?
