I have a 2004 fuel injected 8 cylinder mercruiser small block. The audio alarm sounds once every minute with 2 beeps. The lower unit oil level is fine, temp, oil pressure fine. It beeps at idle through high speed. I disconnected the lower unit oil resevoir sensor and alarm still beeps. I also jumpered the lower unit oil resevoir sensor and got a slightly different beep along with the original alarm.
Any ideas ?
Any ideas ?
