First of all: excuse my limited English - I'm from Norwayo
I have a strange periodical problem with tilting my engine up. This problem have never happened once I'm running the tilt up. But periodical after a trip out fishing it's not possible to tilt my engine up.
I have read a lot of topics regarding this but still haven't found anything like this:
First of all I checked my 2 relays as stated in most topics regarding this problem. I have four relays inside this box and found out that the tilt function are te two in front on the starboard side. Therefore I tried to replace them with the two located on the back with same result.
Then I tried to messure the voltage on the engine side that are supposed to give 12V to the coil on theese relays.
Had 12V on the lower when pushing down switch and 12V when pushing up switch.
But here comes the strange things:
When I connect the relays again (this time with cables so I could do some messuring). The upper relay didn't get 12V anymore. But again: if I take this relay and switch it with ex. the lower one I still don't get 12V to it.
I was sure that I had a 12V problem feeding the upper relay and started to investigate some more. I guess the 12V feed to the relay are the blue/white cable? But this cable seems to come from the lower side of the engine.....does it go from the tilt switch via a limit switch or something on the tilt pump? Anyway: I couldn't figure out way I got a periodical failure here.
So I decided to get the boat out of the water. So I figured out that I could force the tilt up switching the thick green and blue cable and then use the down switch.
This was a success - the tilt went all the way up.
But here tthings gets really frustating. When I switch back the pump cables to normal - the tilt are are working both up and down again!!
I was using the boat every day for 2 weeks without any failure at all. And then suddenly, same story - coming in form fishing - no up tilt and no clicking on the relay - switching the cables - running the tilt up with down button - and tilt working again both directions.....
It seems like something is happening when I manage to tilt my engine all the way up. If I tilt it just 10cm and then switch the cables again I still can't use the up switch to tilt it.
I haven't checked the fluid on my pump (and I do have some strange noises sometimes - but just sometimes when tilting up).
But for me this seems like an electrical problem - but I can't find it. And since I do not have a diagram I'm out of ideas where to look.
Yesterday I'm sure I was smelling burnt electronic when I was trolling - and 10minuttes later the up switch didn't give ant respons.
I'm sorry for this looooooong post - but was hoping that maybe someone could help me some steps forward here instead of telling me the usually stuff like switching the relays8)
