JoeMan
- Jun 29, 2006
- 332
Picked up a nice condition '95 Merc 60 horse, has 3 carbs, each is one barrel. Previous owner told me he fiddled with the adjustment screws, and told me it's out of sync. He obviously should NOT have. It shakes and coughs a little when idling, and runs rough in general. What I've done thus far. New gas, new fuel filter, new plugs, cleaned carbs with Hog Wash carb cleaner until they sparkle in and out. Compression is good in all 3 cylinders, it runs cool. So my request of a Merc outboard expert (and I know you're here) is this. I want to make the carb adjustments myself, but have not done so before. I've made adjustments to my cars and lawn mowers, but I'm NOT assuming this is the same...so please be specific! There are 3 brass adjusting screws that I can see on the right side of each carb...a larger one towards the bottom, a smaller flat one which looks like it has a very narrow 'hole' in the center of it, and next to that one, another brass screw which protrudes out a bit and has a spring under the head. Which do I make adjustments to at low idle to sync, and which at higher idle? Tell me what to listen for, etc. You won't be held liable, I promise! I'm eager to get this thing running smoothly and learn something in the process. THANKS in advance!!!
