using small battery
bobbykey
I have a 35hp engine on a small boat that i start with pull cord because the starter has been removed.My question is can I use a small motor cycle battery on the motor since the starter is no longer used and there is no electronics used on the boat.
ezeke
Re: using small battery
Hi Bobby,
Most likely, yes. Why don't you give the year and/or model number of your motor so that we can look up the wiring diagram.
bobbykey
model RDS - 21
SERIAL 1892095
its a johnson super seahorse 35hp old motor
Silvertip
If you have no accessories that require 12V, you don't need the battery. It's not required to run the engine.
Evinrude Boater
I used a battery booster pack to start my 75 hp and it was fine. The motorcycle battery should work, you're just going to have to charge it every day.
