Re: Small amounts of metal shaving on my drain plug magnet
Somewhat common on a newly running in gear case.Always make sure you shift briskly from neutral to forward or reverse or it will cause premature wear of the gear lobes.
rick, for clarification , lorins " half the size of a pencil eraser" surely refers to a clump of fine metal hairs mixed with lube and not a single chunk of metal.
Wooooo I was gonna say if you had the half size of a pencil eraser you better do a tear down......In my evinrude 90 and my Johnson 40 I go get "Grey goo for the lack of a better term...fine metalparticles int eh foot oil.......Like OB said it is common
