seven up
- Jun 4, 2006
- 275
Re: Fiberglass Resin vs. Epoxy Resis
shadetree,
When using the epoxy/polyester products on wood you may have noticed from this thread that sealing the wood and keeping it sealed is a priority.
Reading threads like this one and many others has literally saved my project boat from the woodpile.
One especially helpful thread was about using epoxy as a sealer. Well...the epoxy mix of resin + hardener is "watered" with laquer thinner and then brushed/poured/rolled onto the bare wood. In my experience using marine grade woods I have found that this thinned epoxy disappears into the prepared wood. This is, however, a low-priced alternative to commercially produced products made exclusively for this purpose.
I have tried diluting up to 100% and it is truely the consistency of water. There are many types of epoxies and polyesters. I have no experience with polyesters.
And shadetree, if you are putting in chopped strand mat, I have recently heard several times that epoxy will not work.
custombycrunch,
the company i use for epoxy and etc. is US Composites. was surprised when looking at the site yesterday that gelcoat/dump guns are like 120.00. maybe my next project will be fiberglass.
this latest order was for gallon 14-17. no delaminations or failures. always has kicked and cured as it should. the pumps were a waste of my time and caused some mixing screwups with the 3:1.
Enjoy
shadetree,
custombycrunch,
Enjoy
