Re: 72 Mercury 800, Motor dies when Pos. lead is disconnected
I recently bought a bass boat with a 1988 150 horse V6 on it. It wouldn't keep the battery up. Checked the rectifier and found it was bad. Took it off and crossed the numbers on the bottom, and found it was a cheap Mexican 6 amp rectifier encapsulated in a lot of crap that would even de-rate it more.
I replaced the rectifier with a Radio Shack 25 amp 200 volt bridge rectifier. It was a lot of work to make it fit, but I don't expect to ever make that repair again.
I am amazed that Mercury builds expensive motors with such a sophomoric charging system on it. The battery is used to limit the output to a safe level, thus if a battery connection is bad, voltage goes ballistic, and something expensive usually gives. (Maybe I just found the reason for the design.)
Never, never start or run a Mercury engine, even rope start it, without a battery connected.
hope it helps
John
