I am not able to drop the lower unit to service the water pump. The dirve shaft seems to be stuck in the power head! Any thoughts? Anyone ever had this problem?
Yes, all bolts removed, have 1/16 inch between the lower and mid case, have tried to seaperate with 2x4 and hammer, have run the engine with two bolts in loosly.
you should have removed the trim tab and 8 bolts,
if you have not removed the 8 10mm bolts it wont come off, its very very rare to see the shaft stick on a yamaha.
Try tapered building wood shims at the separatation point ,and put a rope on the cavitation plate with a come-a-long and rap on it with a rubber mallet.
