Lift tubes Help!!!!!!!
dnitzh
ok i need some more help!!! the seals on my lift tubes are shot and i cannot fine and seal kits for them can any one help but the only thing is that they are the onld ones un like the new ones these one only have 1 host going into the tubes and not two like all of the newer ones they are like a gravity feed to let them down not a power let down thats y their is only 1 hose and also on my lower unit were their is a port on the left sode is were you could put a hose adapter so u could connect a hose directly into the lower unit so u could start it at you're house i need and black plug tha screws into it for when you're goin out on the water. any help or links would be great thanks Derek
tommays
Re: Lift tubes Help!!!!!!!
Whats a lift tube ?a trim ram ? and what brand is it what year ect :)
Tommays
Fishermark
Not to sound like an English teacher here...8)... but your post is kinda hard to read and understand as is. Add a few periods and / or commas! d:) Regarding the trim rams - sorry, I can't help much there,
beattle55
That's what I was going to say.
dnitzh
ok i need some more help!!! The seals on my lift tubes are shot and i cannot find a seal kits for them. Can any one help but the only thing is that they are the onld ones un like the new ones these one only have 1 hose going into the tubes and not two like all of the newer ones. Mine are like a gravity feed to let them down not a power let down thats y their is only 1 hose. .Also on my lower unit were their is a port on the left sode is were you could put a hose adapter so u could connect a hose directly into the lower unit so u could start it at you're house. I need the black plug tha screws into it for when you're goin out on the water. any help or links would be great thanks Derek
dnitzh
And its a 120 hp merccruser and its the cylinders the move the lower unit up and down
Silvertip
The experts here can't see your boat. Without a model & serial number you won't get much help.
DHPMARINE
If your drive is 1970 thru 1977 the tilt/trim cylinder repair kits are #45522A3,$142.25 each.I suggest you make sure they are rebuildable first.Can you get them apart?
The flushing plug is most likely #19-48751,$2.00.
As you read more here,you'll get used to what information we need to be more acurate. (and help you better)
DHP
dnitzh
no it's a 1969 larson i think what i'll prolly end up doing is finding a pump and new ones. they were fine till one day the trailer didn't flip and it bounced the lower unit off the ground and blew the seals. thank god that was it. but we after that we replaced the cap and made out own seals it will go up but as soon as u hit the gas it goes rite back down.
DHPMARINE
I think the old one line tilt cylnders were just that,and would not stay 'up' for trim.
DHP
dnitzh
well befor bouncing the loweer unit they were fine but after trying to make our own seals it would fall
