I currently have 8:1 compression on my stock 250hp 350. On another forum it is suggested that by going to 1.6:1 rockers with the vortec heads I can get 300hp out of my same setup. I always thought that just changing rockers to increase valvelift was a no no because of spring rates, pushrod geometry etc. That seems too easy. Is this correct info?
Current engine specs are:
crankshaft type - reground/polished cast crank
piston type - Sealed Power cast/dish pistons
camshaft specs -
intake duration is 202 @ 50
exhaust duration is 212 @ 50
intake camlift is 393
exhaust camlift is 408
110 degree lobe seperation
valve specs - 1.94 (intake) + 1.50 (exhaust)
compression ratio - 8:1
camshaft specs -
