1997 2355 Ciera Sunbridge SE Prop.
sprint7tw
I purchased a 1997 Bayline 2355 this year. If other owners of a 2355 would give me guideance on the prop they are using I would be gratefull. The prop I am using is stamped 48-78116-C1-15. This has been rebulit by Michigam Wheel and appears to be in top shape. I have been told this is the wrong prop for the boat. Trimed out I can only get 4400 RPM and a little over 30MPH.
Suggestion would be welcome!
Thank You!
sprint7tw
Re: 1997 2355 Ciera Sunbridge SE Prop.
I left out the engine size in the above post.
Merc 350 5.7
Thank You.
dmarkvid2
I own a 29' ciera sunbridge and have a 15 1/2 x 15 prop. I was having trouble getting on plane until I learned how to use my trim tabs. I was taking off with the tabs up, but I now find that if I start off with them all the way down, it takes no time to be up on plane, and then I ajust them from there, along with useing the out drive trim. I have an OMC 460 King Cobra, and I get 45 to 4800 RPM at WOT.
