Hello,
I'm in the process of rebuilding the carbs on the mentioned outboard. Picked up Sierra carb kits (#18-7042). Everything in kit matches up with the exception of the bearing needle valves. The old ones are reddish in color & fit in the slow speed needle valve hole easily. The new ones are white & wider due to a tapered big end. Seems it would take a good amount of force to get the new one down into the hole. Forcing anything on a carb seems like the wrong thing to do. Hoping someone can tell me whether this is the right replacement bearing to use. Below is a pick of the old & new bearings side by side. Thanks for any help!
Motor Model# 50543B
http://xs.to/xs.php?f=DSCN0357.JPG&h=xs208&d=06431
Brian
Motor Model# 50543B
Brian
