Test Prop
Mas
I'm looking for an on-line source to buy a test prop for my '94 20HP evinrude. I've checked ebay & iBoats...to no luck.
Does anyone know of a resource?
Mas
R.Johnson
Re: Test Prop
Even with a test prop, you need a large baffled tank to run it unless to do the testing at a ramp with the boat on the trailer, but you can do that with a regular prop.
jal
Re: Test Prop
What is a test prop?
Thanks,
jal
Mas
Re: Test Prop
So, a garbage can will not work?
F_R
Re: Test Prop
A test prop works primarily by working against itself. Loosely speaking, sort of the same idea as trying to pick up a chair while sitting on it. But they also have a certain amount of thrust and stir up a lot of commotion in the tank. 20hp is an awful lot of energy to try to dissipate in a garbage can. It would be better than a regular prop, but don't expect to be able to run it very fast in there.
To answer your first question, a Johnson/Evinrude dealer can get you one, if you want him to order it.
Mas
Re: Test Prop
Sounds like I'll have to have the boat in the water. I certainly do not like the idea of tuning/testing my motor while also driving the boat to avoid other boats, chop & other objects.:^
Is a test prop made of plastic ...or metal? And are they relatively cheap?
Thanks for evryone's help,
Mas
F_R
Re: Test Prop
They are metal, at least I've never seen a plastic one. Cheap? I had a complete set of them at the time I quit the outboard repair business in 1978 and left them all behind. Don't tell me what they would be worth today, my heart probably could not stand the shock.
GlasV162
Re: Test Prop
Is there ever anything cheap about owning a boat??
