Engine is a 1999 Yamaha SX200TXRX.
Assuming that I have adjusted the TPS correctly (5V reference voltage and .5V output voltage with throttle valves closed), and have re-connected the throttle link, can I set the idle speed according to the TPS output voltage?
I don't have a multi-meter that can pick up the engine RPM and the Yamaha gauge RPM is only accurate to +/- 100 RPM. What I'd like to do is adjust the idle speed screw to get it somewhere between 700 and 800 on the Yamaha gauge, and then fine tune it using the TPS output voltage.
I don't think there is a published spec for the output voltage at idle, but I have seen .6V and .62V referenced here in the past. Is there a better value I should use?
-- Tom
-- Tom
