Converting 1992 Spl Johnson 28 hp long to short
flyinace
I'd like to convert my 1992 Johnson SPL 28 horsepower long shaft to a short shaft. Does anyone have any idea of how complicated this might be and whats involved? I've been using this on my boat that requires a short shaft. I do believe its slowing me down some. Thanks for any help, Ken
D
DJ
Guest
Re: Converting 1992 Spl Johnson 28 hp long to short
At a minimum, you'll need:
1. New driveshaft. (requires lower unit diassembly)
2. New mid section.
3. Shift rod?
Contact these guys. www.twincityoutboard.com
They can fix you up with used parts and may consider some trade value.
flyinace
2. New mid section.
3. Shift rod?
flyinace
Thanks for the info. I will contact them and see what I'll need. Ken
Chinewalker
The mid-section will be fine - just remove the 5-inch extension section. They did not actually make a short shaft 28 in 1992, so you'll need to find a short shaft from something else. I believe an older 25 hp driveshaft (based on the 31.8 cui block) will be compatible. Best to take your 28 shaft to a dealer and see if you can match it up with one that is exactly 5-inches shorter. I did this to one a month ago or so, a 1988 28SPL.
You can cut the water tube 5-inches shorter, and you can cut 5-inches out of the shift rod.
- Scott
gxxdman
2. New mid section.
3. Shift rod?
gxxdman
I have a similar problem but the other way round - I wish to convert a Long to an Extra Long on an older model Honda BF15A. Will it be difficult and expensive - are there any other options?
John (Scotland)
PS See my recent thread on this to get an idea of the problems I am facing.
Long to Extra Long Shaft Conversion BF15A (Old Style) - Honda and Tohatsu ... repair
