I just picked up an 88 Bayliner Capri 1750 with an OMC 2.3 sterndrive.  This is my first boat and I've been doing all the research I can to inform myself about boat ownership, particularily winterizing the engine.  The boat doesn't have a manual, but I do have an owners manual shipping to me.  I'm trying to at least pull all the drain plugs ASAP because I'm located in Minnesota where it's just starting to freeze.  I've got the boat in the garage which is being heated until I can at least drain all water from the block.  I've been looking around and have only been able to find 2 drain plugs, one on the lower side of the exhaust manifold, and one that seems to be on the block just behind the manifold plug.  I'm flying blind until I get an owners manual and am looking for help.  can anyone tell me where all of the plug locations are on the boat?  This would be really helpful until I get the manual.  I'm also changing fuel filter, oil, gear oil, and fogging it till it dies and fogging the cylinders via the spark plug holes.  If there anything else I should do, please tell me.  I also got a tool with the boat that is some sort of clamp with suction cups on the end with a hose fitting on one side.  I have NO idea what this is for and would agian appreciate some help with what it's for.  I've read the winterization posts here and on other sites and they're all pretty generic.  I need specific help with my Capri 2.3 OHC engine and OMC cobra outdrive.  Thank you in advance for any help.
-Tommy
			-Tommy
