115 control cables question
Frank115
I have a 1979 115L6 and i need to change the shifter and throttle cables due to old age and freying. Is this hard to do and how hard is it to get the adjustments right. I'm pretty mechanical as I fix machines for a living. Also can anyone tell me the model # of the control in the picture. I thank you all ahead of time as i know how helpful the people on this forum are. Thanks
Frank115
Re: 115 control cables question
sorry I 'll try pic again
Frank115
Help i can't post pic for some reason
Frank, It is not hard to change the control cables. If they are the proper length for the boat, buy the same length for replacements, if not, they are available in "foot increments". Ask the store for the correct model cables for that motor. They are very common and usually in stock, but the newer Mercs use a different cable, I believe.
Simply put the motor into neutral and remove the old cables. Install the new ones into the control unit. The control unit splits in half, the cables are held in by cotter pins. There is no adjustment on the control side of the cable. Now route them to the motor, and adjust the shift cable (control in neutral) barrell nut to fit on the shift slide, without moving the shift slide. Now adjust the motor to minimum throttle, and adjust the barrel nut so the cable fits the throttle arm of the motor.
tashasdaddy
be careful opening the controller, the wires may be brittle.
Frank115
Thank you guys you make things so simple compaired to the repair manuel
JUSTINTIME
here is his pic
Frank115
Thanks again Justintime for posting my pic. Now does anyone know the model of this control? Thanks again to all of you
JUSTINTIME
i found it
commander 2000 remote control (16900 Series) 1994 or newer
quicksilver makes it part of mercury
u need to pull ur cables out and mesure them, they could have model numbers on them
Frank115
thanks Justintime for the model.You guys must have great sources to find all these answers
i love reading these posts even though I don't have the issue. It's just neat to see the storm trooper figure all this stuff out
