Re: Rodbolt ... running my 50hp yamaha on meths ..
never tried running one on a fuel such as JP5.
 our dewatering pumps in the USN started on propane and ran on jp5 and they used 2cyl omc 55 looper powerplants.
I dont deal with racing 2 strokes but some friends have, most ran castoroil and methanol.
 for methanol you will most likly have to make your own main jetting as it takes roughly twice as much meth as gasoline to run. actually most alchohol based fuels are actually about 100 octane or so but they lend themselves well to nitro methane. nitro methane is simply an oxygen bearing liquid that allows extra oxygen to be introduced in the fuel stream.
                              Methanol       Ethanol     Unleaded Gasoline
RON                               106            107           92 - 98
MON                                92             89           80 - 90
Heat of Vaporisation    (MJ/kg)     1.154          0.913        0.3044
Nett Heating Value      (MJ/kg)    19.95          26.68        42 - 44
Vapour Pressure @ 38C    (kPa)     31.9           16.0         48 - 108
Flame Temperature        ( C )   1870           1920          2030
Stoich. Flame Speed.    ( m/s )     0.43           -             0.34
Minimum Ignition Energy ( mJ )      0.14           -             0.29
Lower Flammable Limit   ( vol% )    6.7            3.3           1.3
Upper Flammable Limit   ( vol% )   36.0           19.0           7.1
Autoignition Temperature ( C )    460            360          260 - 460
Flash Point              ( C )     11             13          -43 - -39
a little chart showing a few fuel characteristics.
to actually gain anything with alchohol fuels you MUST extensively modify the crankcase volume by stuffing it to make it smaller and modify the exhaust to allow 2 times the gas to escape.Nitromethane ( CH3NO2) - usually used as a mixture with methanol to reduce
peak flame temperatures - also provides excellent increases in volumetric
efficiency of IC engines - in part because of the lower stoichiometric
air-fuel ratio (1.7:1 for CH3NO2) and relatively high heats of vaporisation
( 0.56 MJ/kg for CH3NO2) result in dramatic cooling of the incoming charge.
   4CH3NO2 + 3O2 -> 4CO2 + 6H20 + 2N2
The nitromethane Specific Energy at stoichiometric ( heat of combustion
divided by air-fuel ratio ) of 6.6, compared to 2.9 for iso-octane,
indicates that the fuel energy delivered to the combustion chamber is
2.3 times that of iso-octane for the same mass of air. Coupled with
the higher flame temperature ( 2400C ), and flame speed (0.5 m/s), it has
been shown that a 50% blend in methanol will increase the power output by
45% over pure methanol, however knock also increased [28].
 while using methanol as a fuel can be fun it gets expensive as you get to be the engineer.
 we ran a 427 chevy in a 67 camero for a bit on a methanol-nitromethane mix.
was fun but took about 2 years to make it work better than gasoline.
http://www.hydroracer.net/forums/showthread.php?t=5233
 a pic of an old konig alky motor
